It is currently Aug Fri 07, 2026 1:12 pm
Post new topic Reply to topic  [ 127 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9
PostPosted: Feb Tue 06, 2007 6:41 pm
Where you qualifing in Bradenton Johhny????
PostPosted: Feb Tue 06, 2007 8:17 pm
...not sure, but I was warned if I went 7.30 anything...I'll get a lead trophy :shock:
PostPosted: Feb Tue 06, 2007 8:27 pm
i dont think that pumpkin would go 7.30 anything
even if you pitched it off a cliff
:shock: :shock:
PostPosted: Feb Tue 06, 2007 8:40 pm
even if you pitched off a cliff
:shock: :shock:
PostPosted: Feb Tue 06, 2007 8:46 pm
So what did you get over last years rules Johhny????
PostPosted: Feb Tue 06, 2007 11:06 pm
It's not that ... I... got anything, I was more worried that they didn't "give" you boys an inch.....now I can build my motor bigger , since it was too small and had too small of a cyl head last year :D
...or....
Use a LS-1 small block with an 11 degree head witch is an OEM cyl head and weigh 2600 with a 454 inch small block :shock:
PostPosted: Feb Tue 06, 2007 11:11 pm
The LS1 small block @ 454 ci interests me, since I have a buzzard '69 camaro, I get a 50 lbs. deduct for it as well as using a factory OEM head which is 11 degrees gets a 100 lbs. deduct also (2600 lbs.)
...remember Huber is like 2800 with a 422ci :shock:
Users browsing this forum: No registered users and 51 guests
